Aeroforce wirig
hockeybawler
What wire did you guys tap into to make the aeroforce gauge start up and shut down when the car turns on or off? I have a 04 grand prix
You don't take the radio out. Inside the car is a fuse box for almost everything on the inside (atleast on 97-03 cars, its in the glovebox), find that fuse box and pull the radio fuse, then use the add a circut there or use the ignition fuse so it comes on when the car does.
one of these things
Alright so on the 04+ cars the only fuse box inside the cabin that I know of is the one next to the passanger door to the right of the glove compartment. Would this be it? And do I need to use a add a fuse or could I just shove the wire in where the fuse goes and then shove the fuse back in?
Alright, I will go out and buy one tomorrow. Thanks for the help! Orielys or autozone should have one right? If not where is the best place to get one?
Since you guys already fixed the issue.
I'd like to mention that Regals.. they don't need to add the fuse for power. Aeroforce works mint right outta the box.
