Can't say I would recomend doing this but i've had the rpm's up to right at 7000 and I have never felt the cam stop pulling any. Xp is the way to go for a moderate setup.
Your going to have to do a maf tune for sure. Adjust the idle to your preference. Case learn it. Just watch the nb o2's (not the best way) to make sure you don't run lean. Should probably be around 920's depending on what you air temp is where you're located.
Me and reptile basicly have it covered. You will notice a Majior difference with this cam for sure.
Zzp recommends this:A PCM with raised shift points (6400) and rev limiter (6800) is recommended
I have my shift points set at 6300 right now.
According to the local member doing my tune.
He claims our stock crank pulley can't handel shift points that high.
Does anybody know if this is true??
