Front Passenger Side Floorboard Flooded Out After Heavy Wet Snow Followed By Rain
AJ1G
Went to use my 2001 GP this morning after we had about 2 inches of heavy wet snow followed by heavy rain all night. Huge lake in the front passenger foot well, was not there when the car was parked early last night. We have had some minor in-leakage on that side and and I suspect the cowl bulb seal is shot (just read the tutorial on changing it). The amount of water this time though was incredible, I pulled out about 2 gallons with my wet vac. It appears that the water came down from the cowl vent air inlet, as the padding below the glove box was saturated.
I suspect that the slushy snow somehow clogged a drain path for the cowling and that the rain water then backed up and got down into the ventilation air intake. But where is the drain? Is it the small screen over by the right rear corner of the hood?
BTW, on other vehicles, I have had problems with wet snow getting into the heater blower impeller, freezing up,and then causing the fan motor thermal fuse to blow when the inrush current hits the stalled motor. Usually takes out all or most of the individual fan speeds.
Chris B.
Stonington, CT
2001 GP
Just picked up the upgraded deflector retrofit piece featured in the above tutorial - man what a rip off = $3.97! Including tax, plus complementary coffee and Christmas cookies at Brustulon GMC in Mystic, CT (used to also be a Pontiac dealer). Looks like an easy cheap fix for a BIG problem. Thanks to the poster of the tutorial!
Easy peasy! Hardest part of the job was getting the two plastic cowl retainer screws to come out. I ended up just grabbing the plastic sleeves the screws thread into with a pair of electrical cutting pliers (dikes) and extracting the sleeves along with the still installed screws tooth-pull style. Just shoved them back in on reassembly, might replace them with some drywall anchor screws with similar expanding sleeves.
As might be expected, the original bulb seal was completely detached and adrift under the cowl....
Hush ..I know when I got mine I was thinking they could charge $20 and people would still think its a deal...well maybe not us
