Serpentine belt wear tester
idk about the app, but gates is highly recommended in the drive system world, i love em. i use all gates belts in my equipment.
I saw it and it looked interesting. might don't use it but it's pretty easy to tell when one needs replacing
Sent from my pager using Morse code. ... .. ... ....
i got a new gates belt when i changed to a 3.4 pulley. it slipped so bad the engine
was actually missing after 5,500 rpms, put the old gatorback belt which was stock
length (gates was actually shorter so not to slip) no slippage at all needless to say
i'll be using gatorback from now on.you can get the supercharger belt # GTR-4060663
and the primary belt #GTR-4060935 both from summit racing, just put in these #s,jimmy
well thanks for the info on the belts never used em before...those numbers for the belts wont work for me. i got the 2 ton LS4
So I looked online at NAPA and didn't see any "Gates" belts for a N/A 3800. Is this an "unofficial" belt?
My factory belt is still good, honestly, but I figured it's been 9 years and it should be changed.
Just go online to local auto parts store...see what the length and number of ribs ur belt is and has...then go back and find one that matches. If its like 1/4 inch smaller it should still be fine
Gates is a "top of the line" belt.
Ahh I see. Thanks. I'll probably pick up a new one soon. *
