Door locked, can not unlock or open
Lowdown112
My passenger door is locked shut and wont open or unlock at all...I was outside in the rain from 4 to 10 trying to fix it... all help appreciated!!
Are your keys in the car and your locked out?
Does the driver door work?
Are you a coupe?
Did it get into an accident?
Are you just weak?
Was it parked on an incline? :p
Are you a coupe?
Are you just weak?
No i have my keys
Yes my driver door works
Im in a sedan
No i didnt get into an accident
No im not weak
No im not in an incline
Does it unlock from the inside?
Wonder if maybe the hinge isn't so good and the door fell low and the lock mechanism got stuck... so use some wood and a jack to lift up the edge of the door and try again.
sounds like the linkage arm fell apart, for the lock.
do you have a key fob? when you work it, can you hear the actuator working?
Okay. Just verifyin some things. I have a coupe and if I park on an incline the passenger door will not open no matter what from my saggy hinge lol
I'd check saggy hinges on the doors or the linkage arm.
