Your 103's are too cold. Use Autolite 104's gapped to 0.060".
You want to run the hottest spark you can.
the higher the number, the hotter it is.
Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK's. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark you can get away with...so running a super cold plug on a larger pulley to combat knock isn't the best plan...OEM replacement ACDelco's, AL606's, and AL605's are basically for stock cars or very small bolt-ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
AC Delco Factory Replacements: Stock
Autolite 606: Stock
Autolite 605: 1 Heat Range Cooler
NGK TR55: 1 Heat Range Cooler
Autolite 104: 2 Heat Ranges Cooler
NGK TR6: 2 Heat Ranges Cooler
Autolite 103: 3 Heat Ranges Cooler
tell me then why its listed as stock replacement by NGK?
2000 PONTIAC GRAND PRIX GTP 3.8 V6 1 FI Supercharged[TABLE="width: 95%"]
[TR]
[TD="bgcolor: #222222"]Spark Plug
[/TD]
[TD="bgcolor: #222222"]Part No.[/TD]
[TD="bgcolor: #222222"]Stock No.[/TD]
[TD="bgcolor: #222222"]Plug Gap[/TD]
[TD="bgcolor: #222222"]Photo[/TD]
[/TR]
[TR]
[TD="bgcolor: #FFFFFF"]V-Power[/TD]
[TD="bgcolor: #FFFFFF"]TR55[/TD]
[TD="bgcolor: #FFFFFF"]3951[/TD]
[TD="bgcolor: #FFFFFF"].060[/TD]
[TD="bgcolor: #FFFFFF"][/TD]![]()
[/TR]
[TR]
[TD="bgcolor: #FFFFFF"]G-Power[/TD]
[TD="bgcolor: #FFFFFF"]TR55GP[/TD]
[TD="bgcolor: #FFFFFF"]3403[/TD]
[/TR]
[TR]
[TD="bgcolor: #FFFFFF"]Laser Platinum[/TD]
[TD="bgcolor: #FFFFFF"]PTR4B-15 * #[/TD]
[TD="bgcolor: #FFFFFF"]5146[/TD]
[/TR]
[TR]
[TD="bgcolor: #FFFFFF"]OE Laser Iridium[/TD]
[TD="bgcolor: #FFFFFF"]ITR4A15 ^[/TD]
[TD="bgcolor: #FFFFFF"]5599[/TD]
[/TR]
[TR]
[TD="bgcolor: #FFFFFF"]Iridium IX[/TD]
[TD="bgcolor: #FFFFFF"]TR55IX[/TD]
[TD="bgcolor: #FFFFFF"]7164[/TD]
[/TR]
[/TABLE]
