nukkinfuttz
if you had say a completely stock engine, which according to what i can find, should run about a 14.9 if you hold your mouth just right... what should be an expected ET by adding only a 3.5" pulley? Thanks
fine, what is the difference in boost and i'll figure it out the hard way.
3.8= ??? PSI
3.5= ??? PSi
For every person with a Series II 3800 the SC pulley swap should be the first thing considered. It offers the largest HP/dollar value of any mod. You will need a special tool to do the install which can be bought or rented. Install time is about 1 hour. If this is the only mod you plan on doing then the 3.5″ pulley should be used. The stock belt can usually be used but we recommend the 4060658 belt or our oversized tensioner pulley. The 3.5″ pulley swap will give you ~20 additional HP.
Read the safely modding your 3800 on this website, it has some semi good info that can help you.
well, thats very interesting. They are just plain Liars, huh? Wow, I'm shocked.
I wouldnt buy pacesetters. They are pretty bad.
