MoarkatsINmuhtrailer
Your tranny is ****ed then if it's black already
That means a lot of clutch material
Bringing this back from the dead.... Does anyone have a specific brand they use? I used Castrol Dex6 last time and less than 20k on the fluid its black. I want to change it out next week, just dont know what to get.
I use Valvoline because it is full synthetic. I've also used GM stuff from the dealer. IMO, it is more important that you change the fluid regularly than the brand of fluid. But if your fluid is black in that short of time, you probably have clutches wearing and you won't be long before a rebuild is in store.
h**p://shop.zzperformance.com/store/p/279-Dexron-VI-Transmission-Fluid.aspx
Use this....Did a shift on my newer trans......Nice shifts. No issues whatsoever. And it is official GM spec fluid.:th_thumbsup-wink:
dex 6 came out in 2005..but, your car being an 05 wouldnt have gotten that yet.
Or you can just go to a dealer and get 2 Gallons of Dex6 ATF....
GM# 88861954 for Gallon - Retail $30.89
GM# 88861037 for Quarts- Retail $ 8.63
Alot of Dealerships will give a break tho so could be less.
EDIT: BTW Before anyone says but ZZP sales it cheaper. Add shipping to that. To me shipping is an additional $8.80 on top of the $22.49 its $31.29 per gallon... or you can go to a local Dealership and probably save some money. If you want the AcDelco Dex6
I know of many guys even 4T60's using Dex 6 and reporting better shifts and cooler temps. Seems good. Walmart has a good priced in house brand of it that most are using and like.
