    TIPS:
Demod of my 99 GTP....many performance parts availalbe
japslpr
PLEASE READ THE ENTIRE POST: ALL PARTS ARE LOCATED IN VIRGINIA BEACH, VA
This post has been started on CLUB GP as well. I will add names to parties that are interested or have bought items listed. I also will post when the part has shipped as well. Tracking info will be sent personally to you via e-mail or pm.
Please email [email protected] if you wish to negotiate price only. Buyers that negotiate price will have an * after their name. However, if I am offered my asking price, that person will then take top priority over any negotiated price. YOU STILL MUST POST IN THIS THREAD WHAT YOU ARE INTERESTED IN regardless of our price negotiations. If you simply email me and do not post, you will not be put on the list. It is much easier to track in the thread than through email.
Paypal is: [email protected]
Buyer will agree to pay the 3% fees when using paypal. This is NON-Negotiable.
All buyers must pay for shipping I had to pay it when I bought the parts you have to pay it when you buy the parts.
Please add a zip code so I may provide a shipping quote of the part you are interested in
NOTICE! All parts are sold AS IS without warranty. Parts listed in this post are used and in known working condition. Some parts are new & never installed and the warranty may be transferrable from the vendor. I have made every attempt to be truthful about what is being sold. I reserve the right to pull a part from this post without notice as long as no money has been transferred. If money has been sent, and a part is to be pulled from the post, a refund will be made immediately to the buyer.
Thanks for looking :th_thumbsup-wink:
SOLD & SHIPPED ITEMS
ARP Head Studs: $30.00 - EDcellent
Comp Cams 1.6 Pro Mag Roller Rockers: $200.00 -02bronzegtp
Stage 4 P&P Heads: $800.00 - EDcellent
Gen 2 Dub Hub w/3.25: $50.00 - wicked irocz
Stage 4 P&P Gen III S/C: $200.00: LoW_K3Y
Ported Gen 3 LIM with PCV passages modified for I/C use: $50.00 - chuckross1957
ZZP Stage 3 IC (GEN 3) & new style Stage 3 Heat Exchanger kit: $700.00 - G8GTP
N* TB Kit w/ LQ4 MAF, 3-5 wire adapters, silicone coupler & Gen 3 adapter plate: $200.00: LoW_K3Y
EGR Block off plates: $5.00 - BoostedGT
W body store High Flow Fuel Pump: $75.00 - adavis
ZZP modded fuel rails w/ SS braided fuel lines (all hardware included to replace your factory fuel lines!) $200.00 - G8GTP
ZZP ICCU: $150.00 - thegerm
Electrical Fuel Pressure: $125.00 - adavis
Mechanical Boost/VAC -30"Hg / 30psi: $25.00 - jerZcavy4120
Mechanical Oil Pressure 0-100psi: $25.00 - soccerballer0508
Trans Temp: $25.00 - jerZcavy4120
Graphite 3 gague pod 97'-03': $20.00 -soccerballer0508
ZZP HUD pod: $10.00 - jerZcavy4120
GMPP Spring & Strut Combo (struts are adjustable, w/ GMPP lowering springs: $500.00: Michelle Lambert
BMR solid front sway bar w/ energy suspension bushings: $75.00 - GlowinGP
BMR solid rear sway bar w/ energy suspension bushings: $75.00 - GlowinGP
Next Level STB front: $50.00 - Elusive85
Next Level STB Rear: $50.00 - Elusive85
Ron Vogel Performance Control Arms w/moog poly bushings: $100.00 - gtpforever
Aluminum Engine Cradle (drop serious weight from your car!): $175.00 - adavis
Anti Pogo Washers: $10.00 - thegerm
18 x 9 Matte Black Deep Dish Bullitt wheels w/ Summitomo HTZ II tires: $800.00 - adavis
GM Transmission Cooler: $50.00 - the wrath
SLP Headers: $300.00 - DanPrixGTP
42.5lb Flow-matched Injectors: $160.00 - Gtpzilla
Rollmaster Double Roller Timing Set: $100.00 - jmakinen
AEM Wideband (30-4100), ZZP Fuel Pump Rewire: $160.00 - wakeboy1337
Caspers High Speed Fan Kit: $50.00 - ls1camino
Caspers Fuel Pump HOT Wire kit: $65.00 - Swiggles
Ron Vogel Gen 1 Belt wrap kit for Gen 3/SC (includes 3.5 and 3.0 idlers): $40.00 - samuelcb409
ARP Main Studs: $25.00 - L36 Killer
GMPP Tubular Trailing Arms: $50.00 - Chris F
S/C Belt pulley kit: $70.00 - frosty
JZFM 258mm Torque Converter 2700stall : $70.00 - 00grandprixgtp
Engine block, pistons, rods, water pump, front cover, ignition coils & module, alternator, misc bolts and brackets: $200.00 - Steve K.
ZZP 3.1 Pulley: $20.00 - Frosty
Fbody dual aluminum piston brake kit w/rotors & ceramic pads (rotors and pads have less than 1k on them): $150.00 - MEaston91
Sonnax upgraded valve body & channel plate: $150.00 - Booba5185
3.29 Single Chain Gears - brand new: $150.00
2.93 Single Chain Gears - brand new: $150.00
7/8" single chain used (rocker type): $50.00
ZZP Mini AFC: $40.00
Engine & Valvetrain
Comp Cam Pushrods: 6 - 7.100" / 6 - 7.050": $50.00
Air Induction & Intercooling
ZZP Gen 1 S/C Hub: $30.00
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMAG0256_zps48615ca9.jpg
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMAG0257_zps396fdfb7.jpg
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMAG0258_zps2b87073c.jpg
Dub Hub Pullies - 6 rib (2.9, 2.8, @$15.00 ea / 2.6 non-slip @ $20.00):
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMG00429-20110615-0833.jpg
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMG00430-20110615-0834.jpg
Electrical
Alternator Power Cable: $7.00
Suspension, Brakes, Wheels
ZZP Offset Black Poly Upper Motor Mounts: $40.00
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/20130107_143941.jpg
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/20130107_143952.jpg
BAER 13" brake kit for fronts, 12" for rear (includes NIB ceramic front pads, drilled and slotted front and rear rotors, dual piston calipers front and rear, brackets front and rear) $500.00 PRICE IS FOR COMPLETE KIT FRONT & REAR (This is the price drop...originally asking $700.00)
More PICS to come
http://i1098.photobucket.com/albums/g363/jrharris223/20130107_145714.jpg
Hoosier QTP 16" x 9.5" D.O.T approved drag slicks w/rims: $150.00
(Nobody likes to race at the track??)
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMG00317-20110605-1029.jpg
http://i1098.photobucket.com/albums/g363/jrharris223/Grand Prix Parts/IMG00315-20110605-1028.jpg
Transmission
ZZP 4340 Input Shaft: $175.00 (price drop...originally $225.00)
Hardened 4th Clutch Shaft: $30.00
Input & 3rd gear Pawl style Ratcheting Sprag: $50.00 set (price drop: originally $60.00 - includes both the input, 3rd and splined shaft)
NAPA Axels w/gm style carrier: $50.00/pair
4T65 HD Diff Kit: $200.00 (includes HD diff, cover, HD axel and bearing)
Happy Shopping! ;)
Supercharger and LIM back up for sale.
I will run a deal for these items if purchased together.
S/C, LIM, BELT WRAP KIT, ZIP STAGE 3 IC KIT, N* kit w/MAF: $1100.00. I can ship this all together and ready to go. Excludes shipping and pp fee.
May be interested in the intercooler if I find a regal in the next few days.
Cool...let me know
HUD update. you guys are 2 and 3 in line. I have a guy that was interested in the club gp post that posted on 9/27 for a quote. I pm'd him to see if he is still interested. If I don't hear from him today, it will go to the next in line.
jerZyCavy4120...I have the boost gauge still as well.
lol i see u had first dibs on pmd but not on a hud gauge YOU STILL MUST POST IN THIS THREAD WHAT YOU ARE INTERESTED IN regardless of our price negotiations. If you simply email me and do not post, you will not be put on the list. It is much easier to track in the thread than through email.
i like to follow the rules of the poster
ill take those sway bars if the other guy backs out bruh
oh and possibly those ron vogal arms if i get some pics!
ok.
earlybird gets the worm in this case.
sorry.
Updated sold items and new interested buyers. For those of you waiting on quotes, I will be working on them this week. Been really busy with home life and working on getting all these parts off and boxed, weighed and shipped.
Thanks for your patience!
:th_jester:
