stealthee
Long story short.
Car is an 07 GT (supercharged). I did the coolant elbows about 2 months ago and all was well.
I started noticing coolant loss about a week ago. After looking around it appeared to me that the lower elbow might have been leaking since it seemed to be wet and it looked like the serpentine belt was flinging coolant. I did coolant elbows again on Sunday.
It appears the elbows were not the problem. I actually have a semi-significant leak, but I am unable to source it. There is a steady drip running down the crossmember that runs to the front part of the subframe even with the car not running. I looked everywhere and its source is mystifying me. I even got up under the car and in the wheel well and got antifreeze dripped in my mouth looking for this damned leak.
Does this sound like it could be the water pump, or water pump gasket?
Also i noticed a little rubber elbow coming out of the firewall. It appears to me to be where condensation would run off from the condeser. There was what I would consider to be a hell of a lot of condensation dripping out considering I haven't used the AC in over a week. Does that sound like some sort of issue as well?
Thanks for any help that can be offered. Hopefully it doesn't completely let go on me and I can make it to the weekend keeping it topped off, or I can get it fixed before that.
