3000 stall is plenty, also what a stock converter will stall to. With your setup you have the potential to lay down some pretty healthy numbers and an aftermarket converter may be the safest option-though you havent had the best luck. My converters are $574.95 and are custom built to match your combo, have a 2 year warranty, and one free stall change.
The JXFM is the highest stall option for the 258mm converters. I prefer using them as they have a slightly larger lockup clutch surface than the 245mm converters and also seem to be a little tigher on the top end. I have run lots of 258mm converters in cars down into the low 12s and never had one fail
It should work fine. Buying an aftermarket one would be best and more durable but you should be fine for a while with a reman replacement and it may last indefinately. There are a number of local guys that I built transmissions for and a few deep into the low 12s with 140K mile original torque converters, that speaks for itself to me :th_thumbsup-wink:
LOL yeah I feel bad every time you call! That converter should work just fine for you.But hey, rebuilding the tranny is nothing new to me...hahaha
