Need some help from the enthusiast here.
Here's the problem:
When stepping on the brake and the A/C is running, the fuse blows. What this means is the ABS light comes on and the A/C stop working, but the blow continues to work. Upon checking the fuse box under the hood I see that the A/C system and the ABS system is tied into one fuse.
Also, the fan blower for the HVAC system is only working on position 1 and 5. 2 thru 4 don't work. That should not be a problem, I'll change out the fan motor rheostat.
Now, I can get the A/C to engage and I see the clutch engage and disengage after I change out the fuse (10A), only if the vehicle is in park and I don't touch the brake. Once you press the brake pedal the fuse blows (location 18 in the fuse box).
Additionally, I can operate the vehicle with a new fuse and the ABS doesn't come on but I can't run the A/C within the HVAC system, only the vent/blower motor.
Now, I have got the A/C system to work with a good fuse and press the brake when the HVAC system is in position of de-frost or the venting system is positioned toward the windshield and not the vent pointed toward the driver/passenger.
I could find the answer to my question if I had the wiring diagram or if one of you guys happen to know about this exact problem.
Any help?
Jim
Here's the problem:
Any help?
Jim
