Noob Introduction
sparker781
Hey All
Thanks for stopping by. I am currently an owner of a 2005 Pontiac Grand Prix and was in the market for a new keyfob. The one I currently have the battery died on and when i pried off the top the little metal casing that holds the battery to the connectors has broke off.
Any assistance is helpful
Thanks
You will need to do one of 3 things depending on your abilities.
1) replace and reprogram a new FOB, use the # on the back to find a direct replacement or see dealer.
2) toss the Fob and use the key, old school style
3) Break out your surgical precision skills and soldering iron and solder and reconnect the 3 points on the terminal. I've done it and it worked well for a while. Nice way to look at it, its already broken, trying to fix it won't make it any worse. If it doesn't work, you can still order a replacement.
Either way, Good Luck
Hey All
Thanks
You may want to check the GM Parts Direct website as well.
If you have any additional questions, please feel free to contact me.
Louis
GM Customer Service
