Scottydoggs
Killa Bee
well not crack it, but smash the electrode.
I hope not. Only 8k on this new engine.. I'll murder her because I'll be expected to fix it.
Sent from my Galaxy Nexus using Tapatalk 2
I think you should check for a vacuum leak in injector 6. Bad injector Orings could be your culprit.
I plan on it. There is a touchless that has a decent underbody until rear wheels go over and it stops. So ill start there and hope that gets it all.
It is consistently random, it will not miss till 5k sometimes and other times it will miss around 3k rpm. sometimes it wont miss at all. I will make a thread on her tomorrow.
Pull the #6 wire off the O2 sensor connector/body of sensor.
Why..the ground wire in the connector isn't good enough? 92-95 you had to clean the connections.. 96+ they added the wire that is held under the coolant elbow by a nut.
lets just forget the missfire lol
