TEK310
so i have a 97 gtp with a 98+ gen 3.
is there a reason why i cant route the vac hoses like a 97. top of sc to boost actuator to solenoid, to FPR. then just a single vac hose from LIM to MAP sensor, instead of looping them?
i hate having that tee under the snout, i feel like the map will get a more accurate reading as well without looping it.
my only concern is the FPR not getting a solid vac/pressure adjustment, being it is at the end of the line that the vac or boost reaches.
edit: only other reason i can see, is the boost solenoid needs to see vac or boost on both sides to operate properly? how the 97 is set up, it gets boost/vac on both sides, from the top tree and from the side tree
