Save your money. Buy used turbo kit and get a built trans. You will thank me later.
--I should have done that and I have a top swap. I think a lot of people would say the same thing.
If you want to make power yes, but I don't. I'm content wandering around the high 200's with a cool blower whine.
Haven't broke the trans yet. I'll probably break it now won't I.
Regardless, I'm not interested in a $3000 trans just to hold 350-400 WHP.
Wait.. Wtf?
Why would you use l67 heads? Then you have to top swap it anyways.
Leave everything alone, only reason to modify the valve train is if you did a cam or rockers.
The 350 whp nick said, is with stock cam.. You add even just a gt cam to it.. You're looking at around 400 whp
TGP- 266whp- 10 PSI, intercooled CT kit PT 61, M90 block off, 2.5" exhaust, 42lb injectors, CT PCM, , L67 MAF, 42lb injectors, 18" wheels
TGP- 286whp- 11 PSI, Intercooled, CT kit PT 61, M90 block off, plog, 2.5" exhaust, LT1 MAF, ZZP PCM, 42lb injectors, Racetronix fp, 18" wheels
TGP- 346whp- 12 PSI, Intercooled, CT kit PT 61, M90 block off, plog, 2.5" exhaust, cutout, LT1 MAF, ZZP PCM, 42lb injectors, Racetronix fp, 1.9 rockers, 16" wheels
Ideally you'd use L26/L36 top end on an L67/L32. You get slightly better flowing heads, much better LIM/UIM and low compression.
