not that ive seen here.
i did mine, it wa sin a regal, close enough tho.
you need to remove the battery cable first. then remove the airbag from the wheel, how you remove it on a gp i dont really know.
the take the steering wheel off, you will need a puller to get it off. also un clip the radio controls before the wheel comes off. and the horn ground, you push it in and tun it, it comes right out.
then take the plastic off the top and bottom of the column, regal had a torx screw on the bottom and the back side was kinda a hinge clip. gp im not 100 % sure.
now that all that's out of the way, you will see the clock spring, it has a spring clip holding it in place, remove that and it comes out.
at the bottom of the dash, where the obd2 port is, if you look next to it, you will see a yellow plug and a black plug right next to each other, un plug them both, those are from the clock spring. you may need to take the lower plastic and steel knee bolster off to get the zip ties cut off the old clock springs wires from the rest of them, mine had 2 zip ties holding them all together.
once out it looks like this.
So it's for sure broke because of those two things, the SRS light and the radio controls, right? I've been looking around for where to buy a replacement clock spring, but I'm not having much luck. Suppose I could pull one from a salvage car right?
