Why not
Isn't the limiters purpose to keep the engine from blowing?
A rev limiter is a device fitted to an internal combustion engine to restrict its maximum rotational speed. This is usually carried out to prevent damage to the engine, however sometimes these devices are fitted to prevent an engine reaching the point at which it develops maximum power. This may be useful in a driving school car or similar, or utilised in systems preventing Valet parking operatives from joy-riding in high-performance vehicles placed in their charge. When fitted to racing or modified street cars these adjustable devices provide more precise control than the original components built in by the manufacturer. Limiters can be used in conjunction with a shift light, which illuminates when the desired RPM is reached, indicating to the driver that a gear change is required. This allows the driver to keep his eye on the road and not have to glance repeatedly at the tachometer to monitor the engine speed.
From Wiki
Limiters prevent damage to an engine by interrupting the power that is distributed to the spark plugs, this prevents the engine from operating above a pre-determined RPM level known as the redline. The RPM level that results with the spark being arrested can be a constant level, or, with the proper ignition control modules, variable. Variable rate ignition modules can be adjusted quickly and easily to achieve the appropriate RPM limit for different situations, such as street racing, drag racing, road course racing, highway driving, and lawn turfing.
Multiple stage ignition modules offer greater RPM limit control. The first stage can be used to limit RPM levels when launching a vehicle from a stationary position, providing maximum power and traction. The second stage is activated after launch to set a higher RPM limit for wide-open-throttle acceleration.
...This is usually carried out to prevent damage to the engine...
...The first stage can be used to limit RPM levels when launching a vehicle from a stationary position, providing maximum power and traction. The second stage is activated after launch to set a higher RPM limit for wide-open-throttle acceleration.
A) Answer to my Trolling statement "Isn't the limiters purpose to keep the engine from blowing?"
B) GT500 Launch Control
