Wotgtp
Mullet Member
I'm currently planning a build that will mainly consist a gen V swap, NIC cam or similar custom cam design with supporting valvetrain, and meth. Besides the valvetrain the heads will remain stock, and I'll obviously not use an IC. I'm really interested in seeing how much power I can get with this combination, I'm hoping for at least 330whp. The meth portion will be a duel nozzle set up in the lim, and with the power I'm looking for, the nozzles will either be 4 or 5 gph. I know the NIC isn't the most popular cam here, but from what I've seen the gains are solid when backed up with a good tune. Pulley size... Well I'd have to find out at the end of the build to see what I can properly run, but I don't see why I couldn't run at least a 3.0 pulley on this setup.
SLP headers, open cone intake, properly sized plugs, and a P&P lim appropriate to flow well with stock non gasket matched heads will also be on the car. I'm also currently hunting for 42.5lb injectors, and I'm not going to run E85 because I think there's only one or two pumps in CT, and they're not anywhere near me. Thoughts?
