Change to voltage sense and forget about the virtual tach, and physical tach wire. Its in menu 3, option 2
wait.....voltage and virtual tach is different????? I'm confused.
3-2 ENGINE CHECKING VIRTUAL TACH: (1) When set to “virtual tach” the remote
start will monitor the cranking voltage of the vehicle and set that voltage
as a reference point. Fifteen seconds after the crank output sequence the remote
start checks the voltage again to determine if the vehicle is running.
When set to voltage, the unit cranks the starter for the programmed time and
then attempts to sense that the engine is running by detecting an increase in
voltage. When set to Tachometer, the unit references the learned tach signal to
disengage the starter. In addition it will monitor the RPM and shut down if the
engine RPM is too high or too low.
Note: The tach wire must be connected and programmed for the manual transmission
mode to work.
apparently!??
