You notice a difference over the regular oils.
What weight you running.
It's impossible to visually inspect your oil anyway. Oil becomes worn due to the shear of the molecules. The color only reflects that your oil is absorbing and cleaning out carbon, which is its job. You can't see the state of the molecules, so the color tells you nothing.
The 5W and 10W is not a measure of thickness of the motor oil. A 5W-30 and 10W-30 are both 30 weight oils. What the 5W and 10W indicate is the so called 'winter number'. It is an indication of a motor oils resistance to flow in winter. A 5W motor oil will begin to flow sooner than a 10W motor oil.
Not sure if that is what you were trying to point out but there is no thickness or viscosity difference between a 5W-30 and 10W-30. They are both 30 weight oils. Where they differ is in their initial start up flow in cold temps and shear stability in the summer temps.
I personally don't even know where to get Royal Purple.
