Dan's 98 trusty rusty gtp Now with battle scars and weight reduction
Re: Dan's 98 trusty rusty gtp
Installed a aem wb today :D
very nice Dan! i was thinking of a gauge install on the other side after i move my HUD dimmer
looks good. you should of put it down in the little cubby by the center console, ive seen that a few times or a HUD pod
Got some goodies today :D s1x cam, crowe 105 springs, n* tb, lq4 maf, short dogbones, and a high flow fuel filter.
So with the s1x I should just get a new stock timing chain and dampener right? What valve seats and retainers are good ones?
as much work your putting in that car get the rockers fixed and the strut towers replaced..that's what i did. it cost me 150 a side for the rockers labor and 100 a side labor to have the strut towers put in....
Sent from my Transformer TF101 using Tapatalk 2
My inner and outer rockers are shot it's not worth fixing. I'm working on buying a new gtp right now with a good body so I don't have to worry about rust for a little while.
i hear you the inner rockers arent worth it... i may have to get a donor car one day also
Bought some heads today to p&p and a lim. Should work out well with my s1x.
To get a constant 12v at the pump instead of having a voltage drop off from the small gauge of wire used from factory
I love the green. Im looking at buying an green 01 gtp with low kms. Only problem is its 350kms away lol.
Go hustle for that bad boy...:)
Also, green car looks gnarly smuts. Love the newly acquired parts. How much did the AEM WB run you?
