Aftermarket shifters
NinetyEightGTP
This is a pretty unpopular topic (have only seen it a few times), but I would like to replace the factory shifter in my '98 GTP with a ratchet or gated shifter.
Now, I know it's electronically controlled, and this won't improve performance. That's not something I really care about. The problem is that the stock shifter is a flimsy piece of garbage and I'd like something particularly solid and metal.
This fellow here:
put one in his 2000 Bonneville, so it is possible.
Thoughts?
Also, let's preclude the following thoughts shall we:
"You're a ricer if you think this is cool"
"rice rice city"
"So much rice, it could be an independent exporting nation"
"I guess it's cool if you're a card-carrying commie import lover"
If it's possible on the Bonne..it's possible on the W body. the shifters themselves are basically all the same.
Althought I'd wonder where the need is for a serious shifter like that. It's just a matter of setting the space between the gears properly. Seems like that couldn't be tough to measure and setup when both shifters are out and side by side.
For me, the stock shifter is just not solid enough. It's too plasticky, too cheap. I like to rest my hand on it while I'm driving (old habits die hard, etc.)
Plus, have you ever tried to shift from 1st through to D while you're dicking around, only to find that the stock shifter's detents are so soft a slight breeze would push it into the next gear?
the ratchet shifter should only be used for downshifts... The upshifts should be combined with going wideopen, but "shifting" the trans well before the shift point should happen so that the proper electronic settings can be applied to the valvebody/engine.
I would fully support someone putting a ratchet shifter in a gtp... probably one of the biggest upgrades in transmission longevity you could make.
Golly, if anything, I'd want a shorter shifter. I don't think anyone else here rows through their gears because that's an odd thing to do. However, I do emergency downshift about once a year for things like... SUDDENLYAPACKOFDEER). Having a shifter long enough to punch my stereo into park doesn't appeal to me... already a pain to get stuff in/out of the box under the stereo while in park, too.
If you feel lazy/cheap, maybe replace plastic knob with a leather-wrapped one and call it a day.
Something tells me you're being a facetious tool, but I can't put my finger on exactly what it is.
I don't row through the gears constantly, but once was enough to make me realize something about late 90s GM interiors.
they're poop.
Well, if you wind up just changing the knob from your gross 90's knob, I keep trying to get everyone to do a Thrustmaster, since it's incredibly stupid/awesome.
He agrees that you couldn't possibly manually up-shift better than the PCM at WOT due to the valve body being electronically controlled.
Up shifts during normal driving will increase the longevity of the transmission; like preventing skip shifts, 2 to 4 with respect to throttle position.
More accurate down shifts can be achieved with the ratchet.
I think it looks absolutely ridiculous but it makes sense - mechanically. You need to be driving a '70 Chevelle for that to be aesthetically pleasing.
Maybe check out a forum where people actually change shifters... like ten people here tops have even changed their shift knobs.
Aesthetics are subjective.
Your explanation seems rational but I know darkhorizon is a prominent troll on subjects he disagrees with, in fact, I've seen him lambast this very idea before.
That's how I know he's being a ****head.
Sometimes dark's a peckerhead but wuteva, I agree with his post and it's alright if he's being a wisearse.
About the aesthetics - If you could shorten that thing to about half it's height....?
I could get a much shorter one, yes.
If I go with a B&M Hammer (and some others) over the quicksilver.
