Scottydoggs
Killa Bee
look for coolant loss. and puddling around the lim bolts.
bolt that holds LIM to head.
So my wife has the black plastic gasket set on her 05What should I be watching for if this gasket starts to fail? She has about 132k on the GP right now.
This may be a bit off-topic, but kinda fits. I had a 95 Bonnie, which ended up needing the upper intake replaced and new gasket. Was losing all my coolant. It cost $650.Then 6 mos. later was leaking oil. Seemed to be leaking out the intake. Heard the 2pc design was the problem.
Now I bought a 08 GP. Any experiences with these intakes failing (warping) too?
Drive-by-wire?guess I'm lost.
Take a look and see if your gasket is black or silver. Silver means you smile and be happy, black means should replace.
Ohh that's not good.Well we are starting to experience some coolant loss but do not see it leaking anywhere and the car is running fine. No check engine light, no white smoke from the radiator, dip stick oil and oil fill cap look fine (no milkshake looking oil). So before refilling the reservoir with more DexCool, I pop the radiator cap off and the pic below is what I find. Now bear in mind I had the radiator flushed and filled and new hoses put on.
I don't know what you're talking about, but I see orange....lol. Our impala with the 3.8 is the same way.
Or am I looking at the wrong spot?
