F-Body brake question
Thanks for clearing up the confusion
So I think I'll order those bolts and sleeves
Props again for the part numbers. I been putting this off as I didn't want drill and tap anything.
Edit
Part numbers for the bolts to use with the sleeves ?
Sorry man. I currently been I-phoning for the last month or so, and had 8 windows open all for the bolt website. (been too busy with my house remodeling to get on my pc)I didn't want to order 8 bolts just 4. I rarely beg for help, so props to you for doing the leg work for the info!
pretty sure you can use the stock line, they may have to be f body lines.
the ss line makes the pedal firmer i guess, no rubber to swell.
ok thats what i thought i just wasnt 100% sure, does SS lines relly firm up your peddle or is it just a gimmick
What if the calipers from the fbody have the brake lines attached already? I can use those bolts to attach my lines right?
