BillBoost37
91-96 Regal
Note: Existing keyless remotes will be erased with this procedure.
Existing working remotes will have to reprogrammed also.
1. Locate the programming connector wire located in the RH trunk area.
You may have to pull back right side trunk trim on trunk wall to locate
the single black/white wire.
2. The programming connector wire should have one termial in the plastic
connector on end of black/white wire. Ground the terminal in the connector
to a nearby bolt or trunk latch.
Leave connector wire connected to ground through out procedure.
3. System will now lock and unlock doors automatically to indicate
programming mode has been activated.
4. Press any button on keyless remote. System will respond by locking
and unlocking doors one time to indicate successful programming.
5. Repeat step 4 for to program any additonal keyless remotes including
and existing keyless remotes. Do not remove ground wire between
programming of keyless remotes.
6. Disconnect programming connector wire from ground to exit programming
mode.
7. Test keyless remote(s).
97-04 Regal
IMPORTANT: Before entering programming mode, have in possession all of the remotes you will be using on the vehicle. Once you program the remotes , all previous codes will be erased from the memory. The other remotes will not be functional until you program the remotes again.
1. Close the vehicle doors.
2. Insert key in ignition and turn to ON (As far as you can without cranking engine)
3. Turn ignition OFF and remove the key from the ignition.
4. Press and hold the driver side door lock switch in the UNLOCK position.
5. Insert the ignition key into the ignition lock cylinder and remove the key.
| (Do not turn the ignition key in the lock cylinder.)
6. Insert the ignition key into the ignition lock cylinder and remove the key.
7. Insert the ignition key into the ignition lock cylinder. (Do not turn the
ignition key in the lock cylinder.) Leave the ignition key in the ignition lock
cylinder.
8. Release the door lock switch. The vehicle will sound three beeps in order to
verify the Program Mode has been activated.
9. Press the LOCK and UNLOCK buttons together on the keyless entry
transmitter and hold until the vehicle beeps twice to verify that the
transmitter has been successfully programmed (this take approximately 15
seconds).
10. Perform the previous step to program up to four transmitters (including your
old ones).
11. Remove the ignition key in order to exit the Program Mode.
94-96 GP
mode.
97-03 GP
will be useing on the vehicle. Once you program the remote. all previous remotes that were
programmed will be erased from memory. The other remotes will not be functional until you
program the them again.
1. Remove the key from the ignition.
2. Close all doors.
3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
*** owner's manual to properly locate the "MALL PGM" fuse.
4. Insert the key into the ignition, and turn to the ACC position.
5. Turn the key to OFF and then back to ACC within 1 second.
6. Open and close any vehicle door. A chime will be heard when the system enters into
*** programming mode.
7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
************* IMPORTANT: After 7 seconds, a chime may be heard confirming successful
*** synchronization. It is necessary to wait approximately 14 seconds for a second chime
*** that will confirm successful programming.
8. Repeat step 7 now for each additional remotes to be programmed including any existing
* * remotes.
9. Remove key from ignition.
10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
mode.
97-04 Regal
cylinder.
seconds).
old ones).
94-96 GP
mode.
97-03 GP
2. Close all doors.
* * remotes.
