Oh Yo Yo, or is it, Eye Yi Yi, I am just going to come in here to stir this thread up. O/P if you are running boost, and want to fine tune the car, then take the peoples recommendation and get a wide band.
Now to the people that say a narrow band is useless and a light show, thats not totally true. I have another car that I have and will do rough tuning using a narrow band A/F gauge. So now you just spat your coke out on the screen and said ya, how in the hell do you tune with that. Its fairly simple. If I am at WOT nearing redline and that meter does not stay at the top max green or drops to the first yellow, then I know the car is starting to drop down out of full rich. If I notice that while at cruise it is spending more time cycling at the green side I know it is too rich. If I ever see it go into the red at part throttle high rpm I know its running lean. Its not as dumb simple as looking down seeing a number regardless of throttle position and instantly knowing what the engine needs. However if you are gear headed enough, its no less a mystery that tuning a car that does not have an O2 sensor at all. Let alone a narrow band or wide band system. Stuff like running your finger on the inside of an exhaust tip to check for black soot. Smelling the exhaust, listening for the faint sound of detonation or learning how to deal with high speed detonation vs low speed detonation. It took me a long while to come up with a good timing curve for some of the cams that I use, having to increase base timing at low rpms to bring up low rpm torque, and then needing to reduce timing on the same motor as the rpms increased, because cylinder pressures increased enough to cause detonation. (high lift, long @.050 duration cam)
Now back to the O/P by the fact that you didn't know the difference between a narrow band and wide band O2 sensor or the fact that a wide band was even an Air Fuel Ratio meter. I'd say you should get the Wide band or nothing.
P.S. the reason I didn't jump on the wide band bandwagon long ago, when I started tuning cars, Widebands didn't exist, and when I got the early A/F gauges Widebands were around $750. Come to think of it, I think I paid 200 for my first Narrow Band gauge and that didn't include the O2 sensor.
