My belovRed 97 GTP: New RaceKer Trans installed
Re: My 97 GTP
And this one is JUST FOR YOU DAN...
Re: My 97 GTP
YES!!!! you're just like me!!! Kinda.. I still got you beat. Mine will beak your ankle, yours will only stub a toe. But you know what? I'm proud of you for once
Re: My 97 GTP
Jee thanks.... The stock tips were SUCH A ***** to get out of the muffler....
Re: My 97 GTP
Well Cut and Weld was my plan.. BUT stock tips are Alum. cant weld steel to alum. And stock tips mount RIGHT INTO the mufflers... Didnt wanna weld onto mufflers...
So what did you do?
I cut 2 pieces of exhaust pipe to 5" and welded the tips on to them. Then i had to pull stock tips out of mufflers. Very difficult.Then I stuck the other end of the pipe into exit of muffler. Then I secured that by using a muffler clamp around the pipe and the little fingers on the muffler.
Re: My 97 GTP
tucked one of my tips today... Had some hose clamps laying around and used them.. Gotta go get more for the other side.
Re: My 97 GTP
Really just the one spot looks bad.. The other spot I did dont look too bad.... I dont even Know if I am going to TRY fixing the back seat.. That is in BAD shape.
