i make wa baypass for the coolant to the throttle body opinions
gpracing
I made the bypass for the coolant that heats the air that goes to the throttle couse in my country the weather is tropical and is not to cold and i wanna know if this mod is better and if the mod upgrades my cars in something am new in this please any advice or opinion will be welcome.:)
Not sure how you made the "bypass", but if you just blocked it you are starving your rear head of some coolant. The coolant through the throttle body is calibrated with another passage in the LIM to deliver the right amount. If you stop one, you've reduced the amount of coolant reaching the rear head.
True but not a big deal. You can just remove the side cap on teh LIM and knotch it so more goes through that way, that's what I and others do to compensate for that.
Yes, I forgot to mention the solution. But, doesn't that require removal of the LIM so you're not getting shavings into the cooling system?
Well my friend did that to the camaro he owns and it works good and the car runs well a did it´s only for prove i didn´t prove it couse am waiting for the PCV sensor that i buy so when i install the sensor and prove the car i will tell you !
I did, but I'm sure it can be done on the car as long as you have a shopvac and a garden hose to flush it out the hole when you're done.
