szalajka05
07 grand prix gt s/c
Can I add a throttle body spacer and if is where can I pick one up at?
HAI vs CAI. CAI wins :th_nervous:A throttle body spacer doesn't help the 3800 typically. About the only thing it does achieve is a coolant leak over time because it blocks the coolant from the LIM to the TB and the gaskets/spacer etc have enough give that coolant ends up leaking internally.
But reading is for people who don't have M112 swapped V6 Mustangs...
Mouthy arent yah... Was just a simple question and it got answered by one person after a dozen of critics. I must of been mislead when I heard this was a user friendly site... Also whats your beef with the mustang? Everyone has their own projects so why be a hater about something? A 500hp 3.8 with a m112 is actually pretty impressive. Complete sleeper considering it looks completely stock.
...Cobra Eaton M112 Supercharger 5-6psi, inlet and throttle body, GT take-off exhaust, Focus 310lph fuel pump, Modified 99 Lower intake, Custom Aluminum Upper intake, Cobra 39# fuel injectors, Stock Cobra pulley (3.55"), 90mm Lightning MAF
I'd bet you your entire life savings that car doesn't make 500 RWHP.
Didn't you just say it was on a 3.4" as well?
Those mods made 261 RWHP/282 WTQ...and a .15" drop in pulley size make what...275 WHP/300 TQ?
Also...did he build the bottom end? If it is making over 500 RWHP, then it must...because the Ford 3.8 can't handle more than 400-450 RWHP before letting go...according to plenty Ford enthusiasts.
I'm not trying to kick you in the nuts, but man...I'm giving you all of this info to read and learn...and you just choose to ignore it and hope someone holds your hand through the whole process. I understand a couple questions...but you need to look into stuff for yourself as well.
As for the mouthy part...kiddo...you ain't seen anything there yetI also have no beef with any Mustang anywhere, in fact my old man owns a Kona Blue '11 M6 V6 car...with bolt-ons...and I'm sure it makes around 300 RWHP. What I don't care for is outlandish claims and people who get mad when I tell them to go research a little...I'm not stapling your tie to the desk when your asleep and then slapping you...I'm just trying to help; which is the reason why I took a couple weeks out of my own personal time to type up that thread people have linked you...you know...so you can learn too.
But whatevs, it's your call.
Well, now that you know about all the convenient guides stickied here, you can skip the asking step and save time to work moreI work so much that I don't have time to do a sh1t ton of research so its easier to just ask and learn from others mistakes and accomplishments.
I work so much that I don't have time to do a sh1t ton of research so its easier to just ask and learn from others mistakes and accomplishments.![]()
I had a TB spacer once and it worked great....
For
Nitrous
