04 GTP COMP G
WOW i can't believe how dirty my tb was. Bought some tb cleaner from Canadian tire sprayed her down and what a difference.
I couldn't beleive how dirty mine was either. It seems to run better now and have better throttle response. It still stutters or stumbles a bit when I quickly snap the throttle open though for some reason. It would be nice to get that one solved as well.
Did you use a toothbrush to scrub all around? If not you may still have a hangup, also spray the area around the pivot shaft good as well.![]()
I notice a little stutter on my '00 GT if I mash the puddle down. It's like the entire engne cuts off for about a 1/4 second. I figure my tb has to be downright nasty.![]()
Mine is still doing doing the brief stutter, exactlly as you described even after cleaning the very dirty throttle body. I am wondering if it is a sensor causing the problem. I have scanned the car a few times already but nothing ever shows up.
Your best bet would be to disconnect everything from the throttlebody and remove it completelly before cleaning it. If you just take off the airbox and tubing, there is a screen over the opening of the throttlebody. If you have some basic knowledge of working on engines you should be able to manage it fairly easily.Stupid question, but can anyone do a quick 1. 2. 3. writeup for me on how to do this?
Is it as simple as taking off the airbox, and tubing and the TB is right there then I just scrub her down?
Any info would be greatly appreciated.
Steve
God it was basically completely black inside. I can't believe how ditry it was.
