Coolant light flashing, but it's full.
Paranoid
So my low coolant light started flashing at me. I've had a small leak so I wasn't too surprised (although I've never let it get that low). I went to fill it up, but the overflow tank was full. I checked the send and return hoses, which were nice and hot so it isn't the thermostat. It is running at normal operating temperature, no overheating or anything. I changed the water pump about a month ago because the last one seized up. The only thing I did just before the light came on was put in new rear speakers, but I don't see how that could be related, unless it's a fuse of some sort.
1. Other than a faulty sensor, what else might this be? I want to be prepared for when I replace the sensor and it still comes on.
2. Where is the freaking sensor? For now I just want to unplug it so it stops flashing in my face. It's super annoying.
It's a sexy 96 3.1 SE.
No air in the system. Bled it then bled it again. I'll try cleaning it.....once I find the darn thing. Thanks guys!
No worries..It's a 3.1L and it's merely saying "hi, I'm about to fail in some catastrophic and graphic display of affection to you, prep your wallet."
I'm almost at the 200k mark so I can't complain. I'll still look cool pushing it everywhere, right?
Haha I love this car. Of course a 3800 would be nice....but I'm proud of my car. It runs like a champ, disregarding small things like this and my blinker. I'd like to do a top swap, but I doubt it's worth it. Oh, and it's sexy too :)
3500 Top Swap with ported crap wouldn't be bad if you'd be in there swapping all the gaskets out anyways...right?
I am dealing with this same issue with my 99 gtp! recently had a coolant leak in a prestone t-fill that was installed in the car by previous owner and that had faulted out! replaced it with a new one, and no more leaks. filled everything back up, and no over heating car runs good, optimal temps but light won't quit flashing:( its like finishing a race and realizing you forgot to cross the finish line lol! I totally feel ur pain "paraniod"
Mines been flashing for years I it does not overheat and coolant level is fine I am guessing bad sensor I'd change it but don't feel like bleeding system
