Gas laws > blues common sense.
No thanks because a ported outlet flows better for one.
Allows the blower temp to drop.
Less parasitic loss from the temperature drop.
But we could be here all day and the gains are there but you won't really notice anything...but it won't hurt to do it.
Alky did PM me, but...I didn't reply...so, let's build a supercharger dyno out of cardboard, elmers glue, and popsickle sticks.
Seems relevant.
Based on what?
Based on what? More in the same space means it'll heat up more. Gas laws can't be ignored.
But you said it flows more, which means it costs more power to turn the blower.
How so? If you reduce flow, that does hurt performance. If all you do is reduce flow, then yes, you can run a smaller pulley with the same flow mods.
But its not productive as the blower spins faster it uses more power to turn it. Only benefit is noise.
Blue, y u no reply?
I can think of a few ways to make a blower test bench. The only issue would be it would only be relative, not absolute. But thats like any dyno or flow bench in the history of cars. :th_jester:
:th_laugh-pointup: :th_laugh-spit: How funny no one here has talked about rotor timing and lead-ins. There is more too it than just opening up the inlet and outlet to what looks good. Granted, the 3800 M90 does'nt get the huge gains in hp that the Cobra M112 does from a port due to its straight through design, but there are gains to be had. But what do I know? I'm sure another "expert" like copgtp will come in here and chime in. I'd actually like to hear what Reptile has to say about all this ( I respect his opinion), although I'm not sure if he messes with rotor timing at all or just ports the inlet and outlet.
BTW my dyno has about 100 hp to spin the M112 to 18000 rpm. Not sure on the M90 (yet) but it takes a bunch of power to turn these little bastards. Maybe hook one up directly to your transaxle.
I don't think you understand what I said. At all.
The "timing" being what?
The rotors have to be "timed" to leave proper clearance between the rotors at all times.
So playing with "timing" of the rotors relative to each other is impossible.
Perhaps you're referring to playing with changing the "overlap" between when a rotor is open to the inlet and to when it seals against the side of the case. Like-wise with the outlet.
people are mad. So should i just clean up the arrow or make it a v also im still confused about the inlet of the sc where the tb goes
