would it be a bad ideal to change the supercharger oil at 128,000 miles
pontiacmanj2
would it be a bad ideal to change the supercharger oil at 128,000 miles. Idk if it ever has been change, and what would be a good thing to use to suck out the oil? Thanks Johnny.
A lot of people use turkey basters, bottle sprayers or hand pump siphon systems.
Its NEVER a bad time to change supercharger oil. It always smells great!
If it'll give you peace of mind, do it. If you do, after you drain it, you might as well replace the coupler while you're at it. Then you prolly wont ever need to touch it again.
GM Maintenance guide in your owners manual states to check and change if needed every 30,000 miles... It most likely has never been done, most people don't even know the supercharger snout HAS fluid in it :th_shakinghead1:. Do it... Do it now.
