L67 coil mount/engine mount bracket (passenger side) on an L36
BlownBigBlock
On my 02', for the passenger side engine mount bracket/coil pack mount, it's 3 pieces. An aluminum piece that the dogbone slides into. A steel support piece that mounts to that and of course an aluminum piece that the coil pack mounts onto. Would this piece from an L67 replace all that without issue??? Here's a picture of the L67 piece, any help would be appreciated.
Yup, it bolts right on, just like your busted L36 bracket would.
I've always been a fan of the L67 ones anyways...cast iron > aluminum mount wise. You'd just leave the supercharged idler pulleys off...looks like so...
No problem.
My silver car actually had one on there when I bought it, so the P.O...probably got tired of swapping them...and I'm sure he did it more than once since the mounts I yanked out of the bottom of that car were beyond destroyed. That thing felt pretty solid with solid rubber motor/trans mounts, poly upper squares, stock DB bushings in the back, for the record.
No problem.
We need bill to show us that video proving W body mounts will never be as good as H body.
