GT vs GTP. With 2 Videos!
Status
Not open for further replies.
Your car is stock? -- Time for some maintenance.
Yes sir, car is completely stock. I would like to start modding relatively soon but I want the car to look the way I want it to before hand. Hopefully by midsummer ill start my modding career. Probably will just start with a 3.4 setup
Just remember a 3.4 setup that doesn't knock in summer doesn't mean it doesn't knock in fall or winter. :)
Thanks for the encouragement, hoping with a set of SD or SSAC headers with 104s and new plug wires, overkill tune , with a scan gauge to moniter and I should be good
Are you sure you don't already have a 3.4 pulley? Your pulley looks aftermarket, a bit smaller and doesn't look to be black like the stock pulley is. Looks just like my 3.4 pulley.
That'd prob get you to a solid 3.5 setup -- I'd suggest some rockers or a cam to run a 3.4 year round while not dumping fuel and running decent timing. -- Good luck with it though.
Look at that dinner plate, are you blind man?
To add, like ^^said...it's called lighting, and probably since it is stock...and might have a bad snout seal, its called grime, dirt, dust, and build up...which are technically a brown-ish hue, ya dig?
Um, 3.4 pulleys are ''dinner plates'' too. I didn't realize I was talking to you either, ya dig?
How's that china ware you got on that blower then?
It's not an aftermarket pulley.
To add, I'll talk to you if I want.
'merica.
Apparently you can't take the hint.
You =
ive never seen a 3.4 with the lil side walls on a pulley.. plus the man said it was stock over and over.. why da hell would he lie on his own car???.... thats just a pointless argument brewing up... and another thread being shut down.. thanks too.........................................
Press on's had the anti slip ribs at the end.
Maybe he bought the car from someone that didn't know it already had a 3.4 on it? I've heard of it happening .I never said the man was lying either. Good god.
^^^Verz is the alpha thread shut-downer guy. *sigh*. On a better note, he's amazingly full of sh!t. That counts for something.
and you asking him over and over after he said im stock... im completely stock.. apparently he knows... he's stock
Status
