sLpGPGT
ah ok guess ER rockers are comming sooner then i thought thenZZP's page claims 9 WHP peak and 30 WHP at 6000 rpm.
This test vehicle had ER rockers, 180 * stat and some other thing i can't recall.
very very true, i was just gonna wait on tune untill i add everything else so im not wasting money on 2 tunesread the whole thing, the 15 whp power is 6000+rpms. like i said you need a tune so you can atleast rev higher.
but drive it for while, your pcm need to adapt the best it can for the extra air. I had a tune already before i got the hv3, i got the hv3 and went got a retune and overkill said i was running lean so he added extra fuel and timing io noticed a good jump after he was done, just keeps pulling harder now.
thats even after my first tune....so thats why i say TUNE TUNE TUNE makes or breaks the hc3 experience.
will do, thanks dude, overkill is wat ill be leaning toward anywayIM not a mechanic. all i know is what overkill told me when i got my first tune(just cai and u-bend delete & 91 octane tune dont know if that makes a difference) that when i get a hv3 to get a retune, that he would get more power.
so i did that just yesterday, he drove it for a bit, pulled over, said i was running lean so he added fuel and some timing, took a run, did it again,added mroe fuel & timing, took a run, did it again. then he changed some part throttle fuel trims and i was done, and i can honestly say pulls alot better now then it did before the retune.
Ask overkill as i dont know im just going by what he did/said.
haha i rather not do that again for a while, the fuel injectors were a absolute pain in the ASS to get off and on but ill still give it a chance maybe the pcm has to get used to the different air flow like previously stated aboveremove it and see if you still think you lost power?
i think i def lost power overall by installing this, ******* i shoulda waited to put that in
low end and i cant feel any difference top end, i did put 92 gas in and it felt little faster but i honestly cant feel much differencelow-end?
i never felt any gain haha, and yea headers will be the next thing ill add on, most likely good old SD headersI never really felt a huge gain stock with just the HV3 in it. Headers is what I felt the most difference. And like Matt stated, 1-3/4" primaries do seem to make a big impact on low end. But top end it eats.
