Old Thread
Re: Awesome Comp G Commerical. (Makes Me Love My Car Even More!!)
Tap shift isn't useless. How do you get into a lower gear? If i'm going down the highway and someone pulls along side wanting to race I don't just stomp the gas and hope it downshifts really fast to the gear I want.
Well, you should. Your PCM should be tuned to shift better than meatbags.
Nothing is going to shift better than already being in the right gear with the revs up,
You can shift into low gear, whomp on it then pop it back into Drive...
He was also the one that said 8k HIDs had higher light output IIRC.
I've never used tapshift but couldnt you just shift a second or two earlier to get it to shift at the time you want it to shift?
Lol blue... I switched from 8k to 6k and immediately could tell 6k put out more visible light. I know if I dropped down to 4300k or 5000k it'd be the same story. More light!
How do you get an '04 or later in low gear on a roll without whomping it?
If you were waiting to go on the thrid beep from any rolling speed wouldn't you want to already be in the gear you wanted. I can tap down to 2nd at 50 and wait for that third beep.
you could shift it with the shift lever
i do not advise that
You can use tapsh*t but after a few seconds the car automatically shifts back up anyway...
I wouldnt say a 260hp supercharged is regular. Well not when the car first came out anyways but compared to cars now it seems like every car is coming with a turbo lol.
