one other thing that has been happening the past few days is the TRAC OFF light comes on along with ABS light.when this happens i lose cruise control.lights will usually go off after a restart. is this a seperate problem or the problem i have getting worse.sorry i try to put all info in original threads when i post, but my mind goes out of order sometimes.![]()
Bad wheel speed sensor or bad harness to one of your wheel speed sensors.
but it only does it when trans starts acting up.im wondering if its tied into pcs problem.
But they have nothing to do with each other and aren't even tied together anywhere but the PCM. Even then it's still a stretch. The TCS/ABS system is controlled by the EBCM, which talks to the PCM over the OBD2 bus, which controls the transmission.
