Factory PCM with no speed limiter??
Keet04GTP
I tried to see when my car cuts out and it doesn't... What is the speed limited to on an '04 GTP... I haven't put an aftermarket PCM in it yet... I'm confused...:th_scratchhead:
There are other things that will effect the cutoff, but the max speed set in the PCM is 150. There are injector cutoff limits lower, though.
Picture is worth a thousand words.
okay well then what is the differece between all of them??? why does one say 150, then the ec somthing say 142 then 125???
just wondering but why would it shut off at different speeds??? what is the factors to this??
Here's an 02 GTP PCM so you can see the difference.
In Ontario you lose your car at 50k over the limit which is 95 mph. Thats right, lose your car for 1 week and minimum $2000-$10,000 fine. I rate a car form 0-150km as it is expensive after that.
