Adidasdude1989
Ok so im freaked out by all this clicking sound, i have no idea what it is. My ABS light just came on along with the traction off light. Here is a video. HEEEELP!!!!
Well the lights went off so they're not on anymore...Sounds like it time to jack it up and see whats broken.
Nut if the ABS and TC just came on, it may very well be the ABS sensor plug-in and wire banging around against something. Could have come un-clipped.
Very late response so my apologies. It was a wheel bearing torn up horribly. Threw the new one on and wow all the noise i was experiencing before the car become un-drivable were gone. No rubbing when turning no nothing...Then 2 or 3 weeks later, i noticed the right rear was making a little bit of noise and it had just a tiny bit of play to it, took the old bearing off, spun it and noticed some rattling going on, threw another bearing on it and now the car is smooth as can be...still jack it up and check out the front end, jack it on the middle crossbeam in the front and leave the key ON so the steering wheel aint locked and wiggle up and down and side to side for loose parts.
Could be a wheel bearing or even a bad axle shaft.
