ok so this problem just started all of a sudden.
symptoms:
blower motor does not work when car is running.
turning the fan control switch shuts off the head lights.
rear defroster doesn't work.
ac doesn't works.
strange rattling buzzing noise from under hood near firewall when lights are on.
strange click when I turn the blower motor on coming from above the e-brake.
also some times it takes a little bit of cranking the engine over before it starts.
things I checked:
grounds
wiring connections.
fuses.
relays.
the only thing I have not checked that was suggested was the ignition switch. Is there anyway to check that without removing it? also is there anything else I can check that may also cause all these problems?
Thanks for reading
symptoms:
ac doesn't works.
things I checked:
grounds
wiring connections.
fuses.
relays.
Thanks for reading
