Well I'm Starting My Top Swap, Just Some Questions
grandamle91
First I will be swapping my engine harness, Got a GTP ECM w/4t65-E Std tune, Headers, Homemade intake, and a full top end.
Ok now the questions...
1: Is there a good write up on where the sensors and vac lines go?
2: The headers I got from ebay had this extra stuff with it and I have no idea what for. See Pic
First link didn't work, thanks for the second. My other question is the fuel rails, will my l36 lines connect to the l67 rail?
The puller i rented from o'reileys had the special bolts in the kit. I bought them before anyway but the kit had them. And yes the fuel lines will fit, but one of mine kinked so be careful. I have a lot of other info if you need it.
I was under the impression the L36 fuel line did not have a source for a return line. The L67 rails require one. Then again I'm not too familar with the L36 fuel system.
There is a return, its just in a different spot than the L67 one.
Right now I have the tb ported to 75mm and cold intake, the charger ported, lim to match. headers no cat, 3" all the way back then spilt to dauls
