Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The site migration is complete! Hopefully everything transferred properly from the multiple decades old software we were using before. If you notice any issues please let me know, thanks! Also, I'm still working on things like chatbox, etc so hopefully those will be working in the next week or two.
I never got your email, and did send you a PM that day, but didn't hear anything back from you till today, and I have replied to your PM.
4 bolts to remove yes.
There is a spring and a "piston" behind the elbow so take care when you remove it to not loose any parts, and take note how they are installed.
Clean the mating surfaces well, being careful to remove all the old gasket material off the front cover, careful its aluminum, so don't get too rough with it cause you can gouge it.
I just use a good, sharp, new razor blade. But you have to be very, very careful. The razor blade will cut into the aluminum. You need to only scrape off the gasket and not gouge the aluminum.
well got the elbow today in the mail.
i didnt order the gasket, on the cause that a pontiac dealership is like right behind where i live =D
costed me 2.95 [WHAT A SAVE]
lol
well thanks again GR8racingfool!
=D
now just gotta buy some new oil, and oil filter.
any good recommendations?
Personally, it doesn't really matter. You can run the crappiest of oil as long as you are not running your car hard, and change it often. If you run your car hard, or like to go for extended time between changing your oil, then you can run a higher grade oil.
Personally, I run Valvoline 5W30, AC Delco PF52 oil filter (both from Wal-mart) and change my oil every 3k miles.
But again, all depends on application and preference.
OK thats the main thing i wanted to kno. if mattered of kind of oil. well thanks since its up there until i find my keys to get it down[lost my keys] or my dad took thme with him since he thinks i might wanna go racing or cruisin[17 yrs old me]
since there lost im gonna do a oil change, maybe paint the calipers, already dropped a WAI,.
well ill keep u posted once im done with THE main thing i posted [oil filter elbow]
thanks to all
