Polyurethane bushings concerns!! Help
Dont get ZZP poly uppers get Intense or 3800performance.
If you have a lot of vibration and you know or have a tuner you can raise your idle RPMs to compensate.
Have you played with idle speed and felt for vibration?
As long as its not loping, it wont change much till you hit 1000 or so.
well its not a stock setup, its also not being dirven on the highway. its a summer only car that i want to put in car shows but still be ncie to drive on the street... i have some huge plans for this car. i can put up with the vibration so i will do all the poly bushings :)
thanks for all your help :)
You can save money and make your own trans and motor mounts out of stock mounts and some 3M Window Weld
