[FONT=Arial, Helvetica, sans-serif]
Select a high flow surface impingement style filter element[/FONT]
Use as large a filter element as practical for the application[/FONT]
Position the filter so the least amount of dirt and debris will be entering the filter[/FONT]
Maintenance the filter regularly to maintain optimal performance[/FONT]
Use as large of an intake duct as practical to connect the filter element to the engine[/FONT]
Intake duct's interior surface should be as smooth as possible[/FONT]
Avoid rapid changes in diameters/cross-sectional areas through the induction system[/FONT]
Avoid or limit the bends needed in the induction system[/FONT]
Keep the intake track to the engine as short as possible[/FONT]
The induction system should draw 100% of its air from outside the engine bay or where minimally higher than ambient air temperature regions exist[/FONT]
All induction component surfaces that are exposed to higher temperature components and surfaces should be made of highly thermal reflective materials[/FONT]
All surfaces that come in contact with the intake air should be insulated from all potential heat sources
[/FONT]
