boostedcompg
So what your saying is...the computer that's meant to help you..helped you? Fancy that
Funny? It probably means you should lay of the throttle when you're spinning the tires that bad.I hate the trac control on these cars it's terrible, I think it's funny as soon as it rains or snows I have to turn it off so the power isn't killed to the wheels.
So what your saying is...the computer that's meant to help you..helped you? Fancy that![]()
How fast were you going dude? And not all snow conditions are the same. It's based on the premise that it's supposed to do that and the abs technically wouldn't hence you not locking them up, versus you locking them up and building up that snow. But i'll get out if you wish, and record any snow that might be built up just for you, even if there isn't anyIf there's no wall of snow you owe me money
yeah we had packed snow already about 3 to 5 inches of it, on top of the snow that was already snowing. If you can still see concrete, then there'd be no reason to take it the fuse out, i'll go with you on that one that one. It's when you're stopping on packed snow, more than just fresh snow.About 3 inchs of fresh snow
i dont see how snow piling up in front of your tires will stop you faster....and with all that snow and the tires obviously locked up, you now have zero control of the car. ( if your tires aren't spinning you have just lost control of the car)
abs is not meant to pushed to the floor, if you do that you will never stop in time. once it kicks in, let off the brake, reapply them softly and they should not lock on you.
i speak from over 20 years of driving in the snow, with cars and plow trucks. (with and with out abs) in holy chit episodes i have dropped the plow and threw in reverse and floored it to stop in time, not recommended but you do what you must do at times. only time i ever hit someone in the snow was when my brake line blew.
in the old days you would pump the brakes which simulates abs. all abs does is allow you to steer around something, not stop you any faster, ( in snow) if that's what you think abs is all about you are so wrong. leave your abs alone, and don't stab the pedal to the floor.
