I picked up some red silicone vacuum hoses. I did not go aluminum gaskets (I know everyone recommends it). I have everything pretty much stock and was told the aluminum was more for performance modded cars.
I have a 97 as well at at about 200,000 my LIMs went I replaced them with aluminum and I was pure stock at that point in fact mostly still am except for ram air added a year ago was recommend by the DEALER said that they they had a problem with those gaskets and came out with the aluminum ones to replace them so they would never have to be replaced again. Car seem to be running fine 110,000 mile later. Who said told you they are for modded cars?I picked up some red silicone vacuum hoses. I did not go aluminum gaskets (I know everyone recommends it). I have everything pretty much stock and was told the aluminum was more for performance modded cars.
curious what kind of shoddy work would ead to replaceing plugs and wires I remember when you had them replaced said the guy took 4 hours? should have been able to just clean and replace them or did he not tuck wire right and they melted?97 with 213 k. Doing all gaskets,cleaning some nasty clogged stuff. New crankshaft position sensor. Had to put new plugs and wires in again only about a week after i had replaced because the work was shoddy. Also gonna be replacing coolant elbows and all vacuum lines. If i had more money id replace all coolant hoses,thermostat,flush.(Oh yeah also replaced the ignition coil module, wasnt getting good spark)
So let me translate that- "I didn't want to spend the extra money on something that I know WILL fail again and could potentially damage my motor. GM updated the gasket design and installed on all mid 04 and later 3800 motors just so they could charge more for the car."
Why would go through all that work just to do it over again? And whoever told you the Alum. LIM gaskets are for modded cars needs to quit giving you advice, or you need to quit listening. I'll bet that person also told you that you could do burnouts w/o toasting your transmission. Do yourself a favor and get the alum. ones. It'll pay in the long run when you don't have to tear your motor back down to replace them again.
