Spartan GL's Build Thread: (09-21-14) New photos!
Re: Spartan GL's (10/21/2011) PG 12 for Trans photo!
^^^What this guy said. Otherwise it's coming along nicely.
Well, for one thing I would of thought it would be easier to put the LCA on the car
then put the spindle on rather than trying to do it in the grass. Good luck with updates.
the LCA went on so damn easy..
now.. the rear trailing arm removal for that one ****ing bolt held us up for ever..
PB blaster, a Torch, and then a large irish man beating the living **** out of the hub with a hammer and it finally came loose.
Today is passenger side Struts, Trailing arms, and LCA.
ill post better photos today
Glad to see all these parts finally going on the vehicle. Great work so far.
side by side compare
All new stuff going in
alittle fan love
rears installed
fronts
fronts better angle
old struts, springs, LCA, rear trailing arms
Re: Spartan GL's (12/10/11) PG 14 for Suspension photos!
Joey, why'd you decide to bend the brake shield on the right rear? New mod XD?
Looks good man, should be a dream to drive around....Need to take it to Us-129, and do it some justice.
i bent the dust shield so i could get to the trailing arm bolt.
i bent it back... lol the car is in dire need of an alignment now haha
XD, I'd imagine. Got it all done now??
the suspension stuff yes,
my buddy tore a small hole in the Driverside CV axle boot... and it is leaking. so ill replace that when i rip the trans out.
also for some reason my tire is hitting the control arm.
what springs are you running?
Vogtland Springs
AGX Struts
New strut plates
Pogo Washers
New Hub Bearings
Stock brakes (Havent installed the GXP yet)
GMPP Sway bars
ZZP Aluminum Control arms
ZZP Trailing arms
jesus dude
anything on the suspension your not changing out
Those are the other two control arms on the rear suspension.
What stance? I got more than that and I'm not stanced :D
lol well there is alot less wheel gap then before.. and the springs will take a few days to compress for further drop.
see how much gap i had in the rear
