Tuner-Extraordinaire
L26 = weak rods
bring the aeroforce by and I'll show you what you gotta do.
The 06 torque conv will be one step up from stock, very small step.
L26 = weak rods
search?......youtube?
Dynapack measures at the hub right? As in with the wheels off.
Might be altitude that resulted in higher numbers, Actually.
Yeah....actually that would result in much lower output.
Going from high altitude to low altitude would read higher.
To the OP, with an GenV, L26, 3.4 and an XP cam you're looking at 270-280whp SAE on a dynojet with a good tune.
Whereabouts in Ontario are you?
Nick..I thought your L32, XP, N* setup dyno'd right about 300whp? Wouldn't the L26 in theory with the higher compression do slightly better?
